30 - Run a vacuum line to the fuel pressure regulator and the MAP. The fuel pressure regulator needs to see boost in order to operate correctly. Go ahead and attach the Boost Bypass Valve to the supercharger. It's held on with a bracket and two bolts. Run a vac line from the tree on the supercharger to the top nipple on the BBV. The bottom one needs to see ATMOSPHERE, because our L36 PCM's cannot control the BBV.
31 - We can now put the exhaust back on. First, connect the HVAC, EVAP and Brake booster vacuum lines. For the exhaust, a 3 inch downpipe should be used to get the most out of your swap. You will need a new gasket for the manifold-downpipe and then downpipe - resonator. Transfer your oxygen sensor and hook it up to the harness.
Okay I might be doing a stop swap soon on my 1999 GP GT. My dad has got a deal on a Buick Park Avenue that has an L67 with a broken harmonic balancer. He wants to do a top swap on my GP. He is pretty savvy under the hood and generally familiar with working on 3800s, but I'm sorta doing the homework before we get into this. He has this whole thread printed out and is gonna look over it. However, I have a few questions:
1. In step 30 (it was just rather confusing), what exactly are we doing? IIRC, we are buying new vacuum lines and adding something that is NOT already on the L67. The reason I'm saying it's not making sense is because if the BBV is ON the supercharger, how/why am I running a vacuum to a tree on a supercharger?
Also, where/what do they look like are the FPR, MAP, and BBV? What should I be looking to do exactly with the 3 of these and a vacuum line? I understand that I will need the L67 MAP sensor and its connector.
Maybe all of this will become very obvious once we start working with the L67 as it is WHOLE and hooked up to the Park Avenue.
2. Is the 3in. downpipe an ABSOLUTE must? I'm pretty sure Dad's gonna want to keep it pretty much stock, so will my GT stock exhaust system be fine?
I read various things about KR and how the downpipe and the U-bend delete would reduce that. And I understand that with more compression and boost you would need more breathing room. But, what I'm not understand is if this top swap is basically making a stock L67 in my GP, then why is there a problem if the L67 basically rolled off the assembly line like this?
Also, we don't have any readers or anything. Dad has a friend that check the engine codes. What is needed to check for KR? What ALL takes it away and what all makes you HAVE KR?? EDUCATE me on KR info. hahah
3. Is the CAI an absolute must as well? Will my GT stock air intake box do just fine?
Other than that I think we can make our way through the steps.
IIRC, we will need the top of the L67, the MAP sensor and its connector, the L67 Throttle Body, and L67 Injectors/Fuel Rail and will have to twist the fuel line's end to fit in the L67 rails.
I just want to make sure I'm getting all bases covered. I'm sure we'll run into something else later on, but this should get us off to a good start. Since my GT is not running right now, is it fine to remove the fuel rail without releasing all the fuel by turning it over? The upper intake is off of my L36 at the moment. The fuel rail is off but not disconnected from lines or anything.
Also, we JUST put a LIM gasket on my L36 in the GP. Must that change/must we undo that; are they the same as the L67?
So other than my questions (sorry, just trying to get it right), I need to get my Grand Prix GT's PCM tuned for the Top Swap and other than that my swap should be smooth with new bolts/gaskets/etc?
Thanks so much! I appreciate any and all help on this.
