97gtp01gt99gt
What about the l67 swap kit do I need that boost bypass valve solenoid wire
So, i got a little confused with the vac routing. Mainly because I was referencing this
I was confused because the write up said to connect the top of the BBV to the "tree" an the bottom should see atmosphere, but didn't mention anything about the SC bypass solenoid. Because of this I didn't know if i was suppose to run a line from the lower BBV nipple to the solenoid and have one of the nipples on the solenoid seeing atmosphere or if i should delete the solenoid and just have the bottom nipple on the BBV see atmosphere. After asking Snowth1ef I learned the the SC bypass solenoid should be deleted and that it is in fact the lower nipple on the BBV that must see atmosphere.
In order to possibly help others I modified the above diagram so that it showed the correct vac routing for a topswaped 3800
Now i need to find a thread that actally talks about my cars problem.
OMG- amazing ! I am not going to be doing a TOPSWAP for the record. I began reading this thread bcuz it said all kinds of info for the 3800 s/c. I couldnt stop reading--until i finished all 22 pages. This was incredible. Now i need to find a thread that actally talks about my cars problem. I'm hoping I find will a discussion that has input from the author of this thread. I'm not an engine wizard or strong enough sometimes to perform car tasks but I love learning about my car and trying to do the maintenance. Thanks again for this thread.
