30 - Run a vacuum line to the fuel pressure regulator and the MAP. The fuel pressure regulator needs to see boost in order to operate correctly. Go ahead and attach the Boost Bypass Valve to the supercharger. It's held on with a bracket and two bolts. Run a vac line from the tree on the supercharger to the top nipple on the BBV. The bottom one needs to see ATMOSPHERE, because our L36 PCM's cannot control the BBV.
no, just run the timing straight up at 0 where it should be.
where does it say that the n/a motor is a degree off? also, if you time it at zero per the marks on the gears then it will be at zero. its not possible for it to be a degree off if you put everything on correctly.
The NA motors have the cam timing off one degree from the factory
