Top Swap Info and Faqs, Also lots of 3800 Info
It unplugs in a couple different places under the hood. There's connectors under the fuse box (they attach to it) and one on the D/S near the brake master cylinder IIRC.
Who said stuff inside had to change? If your tuner said that.. you need to look for a different tuner.
Personally.. I find tossing in a couple of pins is easier than swapping the harness, it's all the same end result
Because the harnesses are different as is the pcm, and I am guessing that the 98+ pcms will not work with the 4t60 trans.
