Slight question, I am about to do a Top swap, I've got a guy, willing to sell me those parts (They comes from a '98 GTP, my GT is a 2000, everything should fit?):
-Heads from SC motor
-Harmonic Balancer From the SC motor
-Tensioner for SC belt
-Idlers for Sc belt
-Coil Pack Bracket
-Lower Intake Manifold from the SC motor
-Fuel Rail
-Fuel Injectors
-Supercharger
-Supercharger Belt
-Throttle Body from SC motor
Is there everything?
Then I plan on getting the Gasket kit on ZZP (Emailed them so they add the rocker bolts to it for convenience) , S/C oil, 180 Thermostat, AL104.
A overkilled pcm tune for the top swap.
And then get the coolant, oil, filters locally.
I have my mech ready to do everything with me. So I took the OP infos, was there all the torque specs?
And now I just saw something about the MAP Sensor, do I need to change it, or will my L36 Map sensor work fine after the top swap?
