i did check the plugs they look perfect. how can i run 7psi at all times, then one random burst of 17psi?
take a look at the zzpoof! pcm you have now, what do you think? I don't know personally, but I wouldnt want them messing around with my motor. They have blown way too many of them up that are SC'ed.
If you trust zzp to do it, then have them do it. Personally I don't trust them for tunes and for me an extra tune is way cheaper than a motor replacement. I just have heard too many bad things about zzp's tuning abilities.
burn your zzp pcm, and replace it with one that works. What do your plugs look like?
WOW, can't believe all the ZZP bashing here, don't seem to recall a ZZP PCM ever blowing a motor due to too much timing/not enough fuel (ala intense PCM's). Way to jump to conclusions, though.
i cant believe youre FLOGGING THE CRAP OUT OF the car with a clogged cat. i swear i will no longer help you with your car if youre just going to break it more when its already broke.
ZZP is the worst canned PCM out there...don't care what you say. DHP, bar none. Or get a custom tune.
