Sooooo Scotty OR I could just send you my PCM and you could tune it for mecanned tunes seem to be hit or miss for some. every car is different.
im using DHP and eddies table modifier thingy. so far all ive really done is installed 05 gp timing and some maf tuning.
i got a top swapped engine im dropping in soon, so ill be starting all over once again soon.
they sell a avt box for like 265, theres a few threads that cover it, it works with dhp. dhp is free to use now, so once you own the box and cables its fully yours to use.
Lots of small things add up.
Be it needing a tune up, dirty MAF sensor, old o2 sensor, brakes dragging, the type of tires you are running, alignment being out etc etc.
How much?you can cut a slot with a hacksaw in the bolt head or use a thin blade grinder then use a flat head screw driver.
when i do send out pcm, being im not a tuner, i delete codes as per the buyer, and install a trans tune set the vin# and such.
if you were closer i could do a in car tune. thats easy enough to do.
I have a 2000 PA Ultra55 shipped. what year are you? im down to one pcm left, its for a 01 to 03. it wont take a older year for some reason. i cant try again tho if your car is older.
