Jrb1027's Blue Beast
jrb1027
So it about time I start a build thread ive been on the forums for a little over a year now, and have never gotten around to making one. Ill start off with all mods that have been done.
Engine
-SLP Headers ceramic coated crossover wrapped
-Borla Mufflers
-Res and Cat delete
-Slp 1.8 rockers (sold)
-Gen V blower
-Frozen Boost Heat exchanger
-Custom modified fuel rails
-Xp cam
-comp 130LBS springs
-double roller timeing chain
-ls7 lifters
-Taylor 10.4 wires
-viton valve seals
-ported heads (polished bowls and some runner work)
-IRC fullsize intercooler
-racetronix wire harness
-60LBS injectors (for e85)
-racetronix fuel pump
-ARP head studs
-intense poly motor mounts
-napa solid rubber lower mounts
-8 rib pulley system
-innovate wideband
-autometer boost
-aeroforce
-victor rienz head gasket kit
-3.4 and 3.0 and maybe 2.8 pulley
Suspension and wheels
-Koni adjustable shocks
-powdercoated lca and suspension componets
-eibach pro kit springs
-tubular trailing arms
-gmpp front and rear sway bars
-f-body brakes powdercoated
-mille miglia evo 5 18s with potenza pole positions
Cosmetic
-street scene grills
-roof rails
-sd ram air hood
-sd spoiler
-everthing under the hood is powder coated silver color is "anodized aluminum"
For now heres a pic of what the exterior looks like
Today I coated my heads and lim I decieded against powder coat due to the high temps, and the fact that I didnt feel comfortable sand blasting them im afraid some sand will get in the valve guides and cause big problems. So I used some vht metalic silver engine paint, I guess we will find out if it holds up, I am going to spray the charger in with the same paint, I finished the front header today, I still have to polish it out but it is ceramic coated and cured. Ill upload pics when I get a chance.
yea i know its getting there, you think i can get by with stock pushrods and ls7 lifters or should i buy 6.95s
Marty from IRC Fabrication makes it......Made a good profit off of selling that one.
XP cam should have been mine......Good thing I was able to pick up and S1X for a good deal instead.
Nah if I wanted to mess with you I'd just ban you......for fun.
Hope the build goes as planned. If it does start saving up for a transmission.
