So it about time I start a build thread ive been on the forums for a little over a year now, and have never gotten around to making one. Ill start off with all mods that have been done.
Engine
-SLP Headers ceramic coated crossover wrapped
-Borla Mufflers
-Res and Cat delete
-Slp 1.8 rockers (sold)
-Gen V blower
Engine mods waiting to go on
-Frozen Boost Heat exchanger
-Custom modified fuel rails
-Xp cam
-comp 130LBS springs
-double roller timeing chain
-ls7 lifters
-Taylor 10.4 wires
-viton valve seals
-ported heads (polished bowls and some runner work)
-IRC fullsize intercooler
-racetronix wire harness
-60LBS injectors (for e85)
-racetronix fuel pump
-ARP head studs
-intense poly motor mounts
-napa solid rubber lower mounts
-8 rib pulley system
-innovate wideband
-autometer boost
-aeroforce
-victor rienz head gasket kit
-3.4 and 3.0 and maybe 2.8 pulley
Suspension and wheels
-Koni adjustable shocks
-eibach pro kit springs
-tubular trailing arms
-gmpp front and rear sway bars
-f-body brakes
-mille miglia evo 5 18s with potenza pole positions
Cosmetic
-street scene grills
-roof rails
-sd ram air hood
-sd spoiler
-everthing under the hood is powder coated silver color is "anodized aluminum"
I think thats everything Ill try to update as things come along, but right now im in the process of getting it back together, just need to powder coat the heads finish ceramic coat on front header, and then all the parts go to the mechanic.
For now heres a pic of what the exterior looks like
