Congrats on the rad instal. I'm thinking of doing mine tomorrow. Glad it brought your temps down. After seeing the huge dex chunks in my heads, I'm near positive the rad is plugged.
Have you considered running any chemical flush through it? I did, and it brought out a little extra crud. I don't think it was too gunked up, but I wanted to be sure the system was clean before I put a new rad in. No sense in clogging up a brand new radiator when a bottle of flush is so cheap, and you're draining the system anyway...
I made a spreadsheet of the transmission cost. JUST the parts were around $700. I spent more on tools and fluids.
[TABLE="width: 1064"]
[TR]
[TD]Description[/TD]
[TD]Source[/TD]
[TD]Ordered[/TD]
[TD]Delivered[/TD]
[TD]quantity[/TD]
[TD]price[/TD]
[TD]total[/TD]
[TD]Notes[/TD]
[/TR]
[TR]
[TD]4T65E Overhaul Kit[/TD]
[TD]TEP[/TD]
[TD]x[/TD]
[TD]x[/TD]
[TD]1 [/TD]
[TD]$79.95[/TD]
[TD]$79.95[/TD]
[TD]K84900M[/TD]
[/TR]
[TR]
[TD]4T65E Molded 2nd Clutch Apply Piston[/TD]
[TD]TEP[/TD]
[TD]x[/TD]
[TD]x[/TD]
[TD]1 [/TD]
[TD]$9.95[/TD]
[TD]$9.95[/TD]
[TD]84928[/TD]
[/TR]
[TR]
[TD]4T65E Molded 3rd Clutch Apply Piston[/TD]
[TD]TEP[/TD]
[TD]x[/TD]
[TD]x[/TD]
[TD]1 [/TD]
[TD]$9.95[/TD]
[TD]$9.95[/TD]
[TD]84930[/TD]
[/TR]
[TR]
[TD]4T65E Gemini Chain Set[/TD]
[TD]TEP[/TD]
[TD]x[/TD]
[TD]x[/TD]
[TD]1 [/TD]
[TD]$89.95[/TD]
[TD]$89.95[/TD]
[TD]HV093[/TD]
[/TR]
[TR]
[TD]4T65E 2nd Steel Plate Oversized[/TD]
[TD]TEP[/TD]
[TD]x[/TD]
[TD]x[/TD]
[TD]2 [/TD]
[TD]$4.95[/TD]
[TD]$9.90[/TD]
[TD]84104P (should have gotten three)[/TD]
[/TR]
[TR]
[TD]4T65E PCS Solenoid 1997-2002[/TD]
[TD]TEP[/TD]
[TD]x[/TD]
[TD]x[/TD]
[TD]1 [/TD]
[TD]$54.95[/TD]
[TD]$54.95[/TD]
[TD]33946[/TD]
[/TR]
[TR]
[TD]4T65E TCC Solenoid[/TD]
[TD]TEP[/TD]
[TD]x[/TD]
[TD]x[/TD]
[TD]1 [/TD]
[TD]$31.95[/TD]
[TD]$31.95[/TD]
[TD]77942[/TD]
[/TR]
[TR]
[TD]4T65E Shift Solenoid[/TD]
[TD]TEP[/TD]
[TD]x[/TD]
[TD]x[/TD]
[TD]2 [/TD]
[TD]$19.95[/TD]
[TD]$39.90[/TD]
[TD]84955[/TD]
[/TR]
[TR]
[TD]4T60E/65E Filter[/TD]
[TD]TEP[/TD]
[TD]x[/TD]
[TD]x[/TD]
[TD]1 [/TD]
[TD]$14.95[/TD]
[TD]$14.95[/TD]
[TD]84710E[/TD]
[/TR]
[TR]
[TD]LubeGard Kooler Kleen[/TD]
[TD]TEP[/TD]
[TD]x[/TD]
[TD]x[/TD]
[TD]1 [/TD]
[TD]$14.95[/TD]
[TD]$14.95[/TD]
[TD]LubeGard-KK[/TD]
[/TR]
[TR]
[TD]4T65E Miscellaneous Used Bolt[/TD]
[TD]TEP[/TD]
[TD]x[/TD]
[TD]x[/TD]
[TD]1 [/TD]
[TD]$0.50[/TD]
[TD]$0.50[/TD]
[TD]Case Cover Bolt ATSG #435[/TD]
[/TR]
[TR]
[TD]4T65E Internal Ring Gear to Park Gear Bearing[/TD]
[TD]TEP[/TD]
[TD]x[/TD]
[TD]x[/TD]
[TD]1 [/TD]
[TD]$14.95[/TD]
[TD]$14.95[/TD]
[TD]84440A (Broke due to my buffoonery)[/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]PNH JTFM TC[/TD]
[TD]Aastro[/TD]
[TD][/TD]
[TD][/TD]
[TD]1 [/TD]
[TD]$130.50[/TD]
[TD]$130.50[/TD]
[TD](Sourced from local trans shop)[/TD]
[/TR]
[TR]
[TD]4T65E Manifold Pressure Switch[/TD]
[TD]Ebay[/TD]
[TD]x[/TD]
[TD]x[/TD]
[TD]1 [/TD]
[TD]$39.99[/TD]
[TD]$39.99[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]Trans-Go Shift Kit[/TD]
[TD]Ebay[/TD]
[TD]x[/TD]
[TD]x[/TD]
[TD]1 [/TD]
[TD]$37.95[/TD]
[TD]$37.95[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]Superior K4t65-e valve body kit[/TD]
[TD]Ebay[/TD]
[TD]x[/TD]
[TD]x[/TD]
[TD]1 [/TD]
[TD]$59.85[/TD]
[TD]$59.85[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]Superior 4t65-e AFL valve repair kit[/TD]
[TD]Amazon[/TD]
[TD]x[/TD]
[TD]x[/TD]
[TD]1 [/TD]
[TD]$22.50[/TD]
[TD]$22.50[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ACDelco 29535617 Pan Magnet[/TD]
[TD]Amazon[/TD]
[TD]x[/TD]
[TD]x[/TD]
[TD]1 [/TD]
[TD]$9.54[/TD]
[TD]$9.54[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ACDelco 24206181 Fluid Pan[/TD]
[TD]Ebay[/TD]
[TD]x[/TD]
[TD]x[/TD]
[TD]1 [/TD]
[TD]$36.40[/TD]
[TD]$36.40[/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD]$708.58[/TD]
[TD]Total
[/TD]
[/TR]
[/TABLE]
That build was pretty much just cleaning EVERYTHING, replacing EVERY seal, and a few upgrades. Nothing really "performance" wise. I think the chain and the valve body work were the most performance-y things, and from what I gathered, that was just kind of, the way it should have been from the factory. Basically, just fixing known issues.
