The box they used was freaking huge. Should be enough cardboard there to re-cover my entire workbench for the next trans build.
I put the new pan gasket and freshly painted oil pan on the motor. Noticed the back knock sensor was smashed, so I swapped it with the front one. Figured if it was junk, it would be a little easier to replace in the front. I teflon taped it and torqued to 14ft lbs. Hope that's right. Everything I saw online said 14lbs.
Because I had the new o-ring, I was able to put the torque converter in the trans.
Three clunks and it sitting at the same depth at the old one. Went on real nice.
And that's where she sits for the night.
My help is coming over after work tomorrow. Hoping to get the trans and motor together and all connection made. I can't put the cradle in till Wednesday when the new motor mount is scheduled to arrive.
Had a couple of junk axles laying around so I made some plugs.
Should come in handy when washing and/or painting the next one.
I managed to break the starter tightening the wires.
Fortunately, I can buy just a solenoid at the pick a part for $6.00. Need to get another knock sensor from there anyway. $7.50 for "Misc. Sensor" is way better than Rock Auto or Amazon' $37 price.
New motor mount should be here tomorrow, so I can raise the cradle.
It is, very pretty lol. Just get rid of the Fram ASAP. Also, did you know that you can get the oil filter off of a S10 with a 4.3L and it'll go right in? It's a taller filter so you get more oil and more filtration.
Thanks!
Can't even begin to tell you how thrilled I was when it actually ran and shifted. No check engine lights either.
Like I say, still needs a radiator. Which isn't all bad. It will give me a chance to fully flush the cooling system. I see red in the reservoir, and green in the radiator... Uh-oh.
I hear there is an upgrade for the radiator, something like a Monte Carlo's radiator. Probably around the same price and since you have to replace it, why not? Want me to look it up for ya?
That would be great! Right now, I can get the Spectra Premium 1" core for $105.48 shipped. A little extra cooling capacity sure wouldn't hurt down here.
Thing that sucks is, it looks like the coolant level sensor is junk. Radiator is full and the "low coolant" light is on. Question is, do I spent $35-$40 on a new one, or roll the dice on a $7.50 junkyard sensor...?
I'd roll the dice on a junkyard sensor, sense they have a warranty and W-bodies are plentiful. Lemme look up the radiator upgrade. You goin through rockauto?
Whenever something breaks, replace it with something better IMO. You have to spend money on something, so might as well put it towards something better.
