Turbocharged400sbc
front end of the crank gets oiled plenty....all times ive found #1 rod and main beatup was because of sucking air, air is not a good lubricant and it likes to find the path of easiest exit....and since the #1 main and rod are the first exits along the oil flow path....the air leads to their death.
most spun rods seem to be the oil choked 2,3,4,5 rods as they are paired together...downstream of the cam bearing restriction. while main galley pressure reads fine, the pressure past the restriction is quite low and drops with the wear and tear accumulating.
same issues inherent in its ancestor the lc2...though at least with a better oil pump design....
