Got the brackets on the frame cut off and ground away. Hit it with some flat black just to stop any rust before I can move on.
I got some assistance of a buddy on drilling the mounts for the rack this time. Still in the processes of welding that up and getting it all settled.
Flywheel, Clutch and PP have arrived and have been used to get the Slave cylinder spacer figured out.
Thanks again to my buddy for getting that one machined for me.
Clutch is a "Stage 3" 6 puck sprung copper ceramic with a PP capable of holding 375 ft-lbs, so the seller says.
Here's part of the Dakota bell housing, with the solstice trans and the Colorado slave cylinder and of course that pretty spacer.
I also have the Wilwood 3/4" bore master cylinder which pairs perfect with the slave and stage 3 clutch.
And I have the Wilwood proportioning block so I can delete the ABS and get my braking system situated.
So I'm currently in the process of getting the steering finished, then I can also focus on getting the brakes done. Then at least I can move the car around and get other work done.
Like another test fit to see where the exhaust and engine mounts can go
