Built 4t65e - The results are in.
Re: Built 4t65e - Quality takes time
Pit any thought to a external remote filter as well? I have plenty of info if you're intrested
summit had a clearance special on the earls billet ford filter stand/housing. some blemished machining on the one I got but it'd work fine
the moroso ford filter or any of the race filters would be plenty of flow and still filter finer than the oem pump inlet "sock"
Good to see...I concentrated on only page 5 today
Haha! There's a lot going on there. Thanks for pointing out something that might have been missed.
Certainly a possibility down the road. With the standalone cooler already plumbed, it wouldn't be too difficult. You guys just run a standard automotive oil filter?
Thanks James. That answers my question. Good point on the filter vs sock. Filter = microns, sock = thousandths (?) Anything that keeps that clutch paste out of the valve body has to be a good thing.
I didn't understand half of what you just said. :th_laugh-lol2:
It's ok essentially the RB series stuff is Nissan inline 6 engines, they sold some in Australia they are 3 liter engines designed to compete with the 2JZ engine from Toyota (350 GM versus 351 Ford)... Essentially I am just looking for a manual transmission from a mid 90s skyline, the non GTR trans is grea tto rebuild to hold gobs of power, I am shooting to make mine good for 1000hp, yet only shooting for 800 to the crank.
Now back to you, I seriously love reading this thread daily for more beautiful transmission pictures. Very nice indeed man, I do like your methods and how you check everything, never hurts to double check.
It's ok essentially the RB series stuff is Nissan inline 6 engines, they sold some in Australia they are 3 liter engines designed to compete with the 2JZ engine from Toyota (350 GM versus 351 Ford)... Essentially I am just looking for a manual transmission from a mid 90s skyline, the non GTR trans is great to rebuild to hold gobs of power, I am shooting to make mine good for 1000hp, yet only shooting for 800 to the crank.
Now that I understand. Sounds like a blast!
Hey, I really appreciate that. My methods go back to my tool and die training. Perfection is the standard. Honestly, part of the reason behind all the pictures is records keeping. It's an easy way to remember exactly what I did. Only takes a couple extra minutes to type up some text and post the pictures. Maybe it will help someone along the way too.
Today was a big day for parts. Things happened at work so I was able to get to the trans shop a day early. 1-2 shift valve, 4th hub, and my super special snap ring showed up!
Price ended up being under $6, so I took it, even though I won't need it on this build. I honestly don't know what makes this snap ring special. The only thing I can think is maybe it's thicker than normal? I don't have another to compare it to. Someone willing to measure one they have sitting around? This one measures 0.077". Give or take...
Fresh valve and solenoid vs old scarred one
And it comes with instructions. Not sure why. If you're this far into a trans, shouldn't you have a manual on hand?
With that, the valve body is finally complete. Waiting for final assembly
Next step was the 4th hub. Didn't want to go all the way down. It's not uncommon for pressed bushings to close up a bit. You can see where the land on the hub shaft was rubbing hard
Hit the shiny spots with some 600 grit. Took a couple times, but eventually it dropped in.
4th stackup
Next the output shaft goes through. A little assembly goo to hold the snap ring on center.
It's in
Metal channel plate gaskets on
Channel plate is next. A little goo to keep the thrust washers in place
It's on
Torqued. I hit the heads with a paint marker one at a time to verify each one has been done
It's about at this point when you realize how close to done it is.
Hit all of the bolts holding the channel plate to case multiple times. With the revised metal gaskets they crush as you make your rounds in tightening and by the time you're done the first few bolts become out of torque spec.......leads to fluid loss. With the original gaskets it's not an issue but with the revised ones I go over it multiple times.
I was not aware of that. Thanks. I will hit them again tonight before the VB goes on.
you missed one
j/k
:th_wavefinger: Don't make me second guess myself. LOL!
Are you enlarging the feed holes on the spacer plate?
You're getting ahead of me Bill. Separator plate mods are on tonight's agenda :th_eyebrows:
What did you do to my little friend the ISS reluctor?
I used a pair of 1/4"-28 button head cap screws. There were 4 existing holes in the driven sprocket that were very close to the 1/4"-28 tap drill diameter, so I went with it. I had to grind some material off the diameter of the heads to clear the boss on the channel plate. Used a drill to spin the screw while grinding. Gives a pretty constant result. When all was said and done, I spun the input shaft in the channel plate to make sure the screws cleared. All good.
Ill take a $2,510 trans:th_biggrin2:
Fixed that for ya!
Since we all know I ripped many of those apart, even when that type of screw was used. I have found a few things that have been done to help with the issues.
Here's what happens if your screws back out.
Here's the one I used in the last trans I built for the Regal. You are correct, it was welded to the gear.
The shop that builds for ZZP, welds the tops of the pins so that they can't loosen and allow slop.
And ... this is from a dynotech trans if I recall properly. It's the sungear in the diff
Yeah, but we all know you're like a professional transmission killer!
I guess anything's possible, but with Loctite, fine threads and an interference fit, it would take a LOT for those screws to back out. I see what you're saying though.
Are the grooves in the sun gear for lubrication?
Might help if I told you I tore up 2 setups that were screwed with loctite and I tore up one from TEP where the holes are drilled smaller in the gear. I was evil to the trans and had some power. Most would tell you it wasn't enough power, however ...I pretty much mastered it since I have pics of at least four times that I did it.
I believe so on the sungear.
Well, it's not too late. Maybe I'll pull the driving gear out and have someone TIG a tack on each one of those screws. That would guarantee they couldn't back out.
