SnowFlake
Banned
at 17 is dont see more than 540 but tq probably real close to it. ill admit to just skimming thread for the details
planning on turning it up some or just feeling it out at a cheap dyno day dealio? 23psi at what pct?
yeah i wanted to do the 144 upgrade to the heap but i decided to shift the alt bracket by machining the 3 bolt to slots... and at that point why not put a 3L plenum on it with the TB setup made much more compact and allow us almost 1.5 feet of straight pipe before the maf.
im sorta figuring its the only way to fix the damn intake distribution issue
btw watch your cyl 5/6 primary temps. they are running lean. we averaged nearly 150-180* hotter than the middle. the way the 1&2 inlets are at the tb neck id almost figure they'd be cooler than 3/4 but they were close enough as youll get with an IR gun.
sometimes i just wanna go with the new megasquirt and quit dealing with not telling the pcm even half what we are really pumping.
Just feeling it out on 17psi.
Even at medium boost it should put down healthy numbers.
According to the compressor charts at 23psi on my setup I'll be just off the right side of the middle island around 75%.
With the 5/6 cylinders leaning out.. that's due to them getting better airflow?
Couldn't just skew the injectors a little to bandaid the issue without going all evil genius on the manifold? Lol
