TheOtherNick
The mod from over yonder
dont gotta shift on the dyno
but save my car for another thread.
This whole BBV thing has me wondering... isn't ours vacuum controlled? Or is it PCM controlled? I used to look at the boost settings in the DHP but I never changed anything.
How does it all work? And if it is PCM controlled, how will the PCM know to control the BBV on my TVS?
its vacuum.
Holy hell and you wonder why I wouldnt let you tune anything I drive?
there is a bbv solenoid.
thats about it.
Whats the table even do?
The solenoid can force the BBV to open under heavy throttle, but otherwise its vacuum operated.
believe me yet your car is pulling timing up top in the RPM and really fvckin your tune!!!!
FOR GODS SAKE GET SOME INJECTORS AND A REAL TUNE BEFORE THIS TVS NONSENSE!!!
the scan is commanded not actual like you've even said a billion times your tune still sucks /END
and this TVS will not make wayyy more power.
The TVS is better yes we've beat that to death 40-50 hp better still doubt it.
the solenoid is an on/off switch if i understand it correctly.
Which kinda makes those tables useless.
Dude... you're pretty freakin' ignorant. You're going to tell me that commanded AFR's will be actual AFR's? That almost never happens exactly...
Also you're completely underestimating how sweet the TVS is.
Well see whos ignorant when your "sweet TVS makes less than the Gen5.
The real test would be real injectors and retune on the gen5 vs injectors and this "schaweet" TVS and a retune that would be each setup identical minus the tune and the supercharger swap.
My moneys still on the Gen5 with some real injectors and a much better tune.
I highly doubt you'll give the Gen5 the chance with better injectors and a better tune their for all this is pointless until you post TVS numbers with that setup to see what it really makes!
Dude seriously Im trying not to hate but this is nothing close to a apples to apples and I cannot comprehend not changing the injectors and tune for the gen5 setup you have.
Raise your hand if your commanded AFR's are always actual AFR's!
*crickets*
I'll throw the 42lbers on just for you babe. I doubt it makes any difference... whats been holding me back from making more power is how much heat the blower is making. Without further modification I will not make more power. As of right now the motor gets plenty of fuel, even with the stock injectors.
