I plan to (hopefully) shake the 3800 community up with an unprecedented (yet painfully obvious) blower swap.
If it works.
What's you theory on using the m62?
Using the M62 provides a cheap road testing out the idea that a smaller and more efficient blower will make more power, even if you need to spin it faster.
Smaller and spinning faster makes HEAT! Which in turn throws your more effecient theory out the window!!
Plus heat makes the need for more cooling reguardless of the SC size.
I will say its IMPOSSIBLE to spin X SC faster and make less heat!
Spinning a smaller SC faster makes no sense when you can use a larger say Gen5 and spin it slower and create less heat.
