New MazdaSpeed3
Re: Gins 04 Comp G 5 speed?
manuals get the one foot brake pedal. yours looks like it need to be trimmed down some. all that does look like fun tho lol
Yup just figuring out where it will sit. Hoping to have the bracket mocked up/welded tomarrow and have it back together cus I have the day off.
Finished up the clutch pedal/ master mounting today so im rather pleased.
This was in my way
So I got rid of it
Interior going back together
Need to cut brake pedal a bit
Now that the hardest part is done I can take a couple days off from work to pull the motor and install the trans. Poly for the trans mount came in today aswell. Going to make a trip to the jy tomarrow to find my ebrake assembly.
How hard was it removing the airbag and steering wheel? I would like to swap my steering wheels soon.
First time cus I didn't know what to do sucked. second time was cake when I forgot to plug in a wire lol. Basicly remove the #9 and #11 fuses I think under hood, should be sir and horn, d/c pos and neg bat cable and put the terminals together to discharge any remaining power in the car. Then unplug the 2 yellow connectors for the drivers side (one is behind the door on the drivers side where the fuse panel is on the pass side, the other is up under where the gas pedal is) I went inside to eat lunch so I waited like 30 mins but because you discharged the power you should be ok to continue. There is 4 notches on the back of the steering wheel, 2 on the left close to each other and 2 on right close to each other. All you have to do is get a flat head that will just fit in the hole and turn it when it bottoms out. Your basicly just moving a bar that is holding the air bag on a spring.
First attempt.. Failed lol stuck a screwdriver in it and started turning seemed like it was doing nothing. Or I was missing whatever I was suppose to be engaging. I'll have to give it another go in the morning.
Thanks for the video Scotty! Makes more sense now I'll give it a go in the morning to many skeeters roaming the area.
Thanks for the video Scotty got the airbag pulled off easily this morning.. Now what about the steering wheel itself Ginseng.. Disconnected everything.. Remove the nut that was holding it down. Anything else. I didn't want to go all Rambo and yank it until I made sure I did everything correct
you need a small puller. i used a small 2 jaw puller, set it up on the threaded shaft once you get the drive bolt good and tight, hit the drive bolt of the puller with a hammer, the wheel will pop free.
Fcuk lol that's what I thought I'll have to go rent one here shortly.
Hmm.. Was gonna go rent one from autozone since its 10 mins down the road vs HF which is in the next town over 40 mins away but I'll probably go buy one just to have for the future
I'll try it again in a few after lunch.. Worse case I'll tap the backseat with a hammer.
if anything should be tapped its the threaded shaft while you pull on the wheel. leave the nut on so the end threads are safe, and you dont hit yourself in the face with the wheel or something lol
