02NavyBlue
Re: Brodon's 02 GT
A friend of mine has a 75,000 btu torpedo. Those things rock. We used it outside just for taking a break from working in the cold. You went from freezing, to too warm in 5 minutes. With my coat open, sitting in front of it, it was on par with sitting in a hot tub.
Mine intermittently wouldn't work on all positions. I was about to replace the ignition witch until it fixed itself. Of course proper diagnosing is always recommended.
75,000 BTU Torpedo with a 5 gallon kerosene tank on it.
pretty sure the blower motor is fine. resistor is bad but it's on the back burner. bad resistor you will still have full high heat. research suggests I have a bad ignition switch.
