cleaningman94
Where would be a good place to get all the bolts to hook up the different things like the pulley bracket and supercharger.
Thin ring landing more likely to fail. Any kr is bad. It means damage is being done to the piston. Takes while for the landing to fail though.
Well it should be fine.
I've beat the crap out of mine at the ~200-270 whp range for two years now. Still together.
But you could be that guy that has it explode instantly. Its not out of the question.
No.
The M90 is a terrible power adder.
Run a larger pulley and keep the suck to a minimum.
Yup, headers and a ported top end.
stock cam? what size pulley? Ever take it to the track for a 1/4 time?
I don't think you read. It's been asked.Ok If I do a top swap on a l36 can I use the l67 pcm?
What exactly do you mean by twisting the head? Do you mean twist and pull the connector off, then replace with L67 connectors?twist the head on the line and itll pop right onto the L67 stuff like normal. make sure the lines arent rubbing on anything, mainly the EGR that'll burn right through them.
