DanPrixGTP
Moderator
Re: 1997 Black GTP, LIM Has Been Completed.
New injector o-rings are on.
Not sure what the hell is causing the misfire or vac leak.
The vac leak is loud, and can easily be heard but a sprayed carb cleaner everywhere and found nothing. LTFTs just chill at 16.4
The misfire on cylinder 6 is real bad too. Not sure whats wrong there easy. The only good part about the misfire, is that its missing like every stroke so my car sounds like it has a small cam at idle. Rofl.
double check your egr delete, you already did injector o-rings yes?
trace your vac line for your ac controls all the way to the vac ball on the driver side behind the bumper in the fenderwell.
i use rtv at all my vac connections with high temp silicon line to be certain no leaks.
i hope my lim is not the cause of the vac leak.
i will be replacing injector o-rings when i install bigger injectors, and replacing my ac vac line with silicon hose, and getting rid of the plastic line.
PS double check the tightness of your LIM bolts
