Status
Not open for further replies.
Re: 1997 Black GTP, No More Dinner Plate.
this is why someone else is incharge of my lim job too lol i dont wanna do an oil change tho lol im lazy,
youre on the bench for this one brando ;) i just hate wasting engine oil lol i just had a change done a few weeks ago
Spent my whole Saturday out at Josh's with him and Brandon.
Completed my LIM gaskets. We had a few rough spots here and there, but nothing goes as planned.
Brandon doing work:
EGR Deleted:
All Back Together:
Car has a nasty Misfire on Cylinder 6. Most stores are closed today, and I'm busy, so wont really be able to investigate it more.
It also has Vac leak. Sounds like it's coming from the MAP sensor, but all looks good back there. Sprayed carb cleaner, but didnt hear the RPM changes.
Here's a few videos I made for the Vac Leak..
2013-03-31_11-46-49_88_zps0714f675.mp4 Video by grandprix2 | Photobucket
2013-03-31_11-48-33_584_zpsaa96b41d.mp4 Video by grandprix2 | Photobucket
But, huge props goes out to Brandon as he did the majority of the work. You da man Brando.
:th_clapping:
Re: 1997 Black GTP, LIM Has Been Completed.
Ha thanks buddy!! Surely that vac leak ain't no big thing we can work it out. I had a blast with you I'd do it all again. :)
Do you know what kind of 3m tape?
For the roof rails
Sent from my SCH-I535 using Tapatalk 2
3M/1/2 in. x 5 ft. Scotch-Mount molding tape (3609NA) | Body Molding Tape | AutoZone.com
I really do appreciate all the help.
And saving my car from blowing up, not only from A LOT of coolant but also from the mad oil leak.. twice.
Now I just need to figure out this Vac leak, it's really pissing me off that I can't find it.
double check your egr delete, you already did injector o-rings yes?
trace your vac line for your ac controls all the way to the vac ball on the driver side behind the bumper in the fenderwell.
i use rtv at all my vac connections with high temp silicon line to be certain no leaks.
i hope my lim is not the cause of the vac leak.
i will be replacing injector o-rings when i install bigger injectors, and replacing my ac vac line with silicon hose, and getting rid of the plastic line.
PS double check the tightness of your LIM bolts
Status
