What did you do to your Car today?
Status
Not open for further replies.
Stuff a chunk of wood in the passenger side springs? :D
Hey now, I have special recent experience with using wood. :D
Have a fat girl sit on your lap until they settle enough?
Or get freaky with said fat girl until they settle?
So I'm looking to replace my ac compressor on my 98 gtp wat other year grand prixs will have an ac compressor that will fit?
Any 97-03 GP air compressor will work but trust me it's worth it to get a new one from advance versus pulling a junkyard one, cause you'll have to crawl under the car to reach it. They're like $130 at advance versus 200 at autozone or oreilly's.
The thing is I have no problem doing it myself plus the junkyard here will let me bring it back if it doesn't work and get another one, also wat do I need to evacuate the freon that's already in there
He means crack a line loose.
You can always take the car to a garage to does AC service and have them evacuate the system properly, then do the swap, then go back to the shop and have them put your freon back in and top it off.
yes, lets all encourage the guy to dump r134a into the atmosphere.. no it isn't as bad for the ozone layer as r22, and r12 were but still.. its not good..
accidents happen sure, but intentional, no cool...
Its not the rest of us have fancy recovery system like you mr. So we make do. If he was ohhhh idk an ac repair person then maybe I would expect more... just saying
[/URL] decided to wash and throw a new hood on...wind deflector needs to go tho..
Did the smoke test on my intake to find that crankcase leak, using my fx fog machine and a hose going in the brake booster vac line. Right away smoke came out of the back side of the motor, I tried more smoke but couldn't get any more to come out which was weird. So I hooked the air compressor right up to the vac line with an air gun, and could feel the air coming out. Turns out that a bracket I removed from the LIM had a bolt that goes into the head. Little did I know that the bolt hole goes all the way through and into the valve cover area, so there was a bolt hole open to the crankcase, allowing water in when I sprayed the engine. So I got the bolt back, cleaned it up and rtv'ed it, and put it back. It's all good now. Then out of curiosity I put air in the intake afterwards to check for any other leaks, I heard one in the front of the engine, eventually finding out it was the oil filler cap o-rings don't seal well after a few psi is in it. Not a big deal to me.
Got a picture of said bolt? Just curious where it is to make sure I didn't take the same bolt out when I did Matts lim gasket.
Status
