Nchristopherson
Hey guys,
Wow has this been a long drawn out process doing this cam swap while I am in college, what a mistake. Anyways, I have a 98 GTP, I was hooking up all of the harness wiring connections again and there is a stray ground wire coming out of the harness that I am not sure where it gets hooked to on the car. It is on the accessory side of the engine and is right next to the brace bar for the alternator. Any ideas on where this ground connection gets hooked up?
Also, I have a heat shield that I have absolutely no recollection of where it goes. It's a 2-bolt half circle aluminum heat shield. Other than that, she's almost ready!
