Steven Monteith
Ok I'll have to check it out tomorrow when I go to the shop. I'll take some closer pics of everything. So these lines not being connected correctly can cause me to not get any power from the supercharger AND xp cam?
not sure, but either way it dont look right at all. and that alone can hurt performance.
how does it idle, smooth? or just the normal cam chop?
It looks like the fpr is gettn vac from the wrong place?
Ok stop guys he has a 97 blower with the vac tree so he does not need that line going under the snout to the T. And from looking at the pic the vac tree isnt even hooked up to anything, that might be your problem.
97-98 with vac tree
98+ without vac tree
Is the vac tree on top of the supercharger that has 3 spouts coming out of it?
The BBV should not be seeing boost. The BBV should be hooked up to a vac line between the tb and the rotors(like the top of the blower outlets)
