Odi
Donating User
I probably sound stupid, but if the rim was on 235 tire, don't I need a new 235 tire? 245 would work on the rim?
yes, stupid question. u can put other sized tires on a rim. 245/45 is the perfect size for 18 in wheel.
if they are rubbing the strut, you want less offset to push the wheel farther away from the strut. however, in your case i expect something else to be wrong because those specs should be super easy to fit without rubbing, tires and wheels.
7" wide wheels make the sidewalls straighter, handle better, less chance of cupping.
Should add that GXP stockers are staggered 255/45R18 front and 225/50R18 rear18 Inch Rims
245/45R18 Stock diameter.
