apierce1289
I'm still learning how the scanner works lol.
Sent from my Droid Razr using Xparent Red Tapatalk 2
When I do long runs for getting LTFT and MAF data I only ever go to 7,000hz when I enter the new data.
I only ever adjust the MAF above 7,000 when I have to add or take away fuel.
Yeah i have never adjusted the 7k+ yet. I also would have to do it with the narrow band since I don't have a wideband yet. I think I might wait until I get one before I start adjusting that.
Sent using my Galaxy SIII on Tapatalk 2
The numbers we are looking for here are mid 11s for a supercharged car or if you are using a narrow band the 940mv range. In that pic I am running very rich, I would need to pull some fueling by scaling the maf table in the editor. Small changes are the best. 2% at a time are ok if you are very far off like I am.
To add fuel you will need to add to the table by multiplying by 1.02, if you need to pull fuel you need to multiply by -1.02. Remember we are only scaling from 7000hz up in the maf table like so.
Perhaps when this was made, you could do that with whatever version of HPT was out. Likely 2.22 or 2.23.
Now with 2.24 and the beta 2.25, just doing .98 is the only way to reduce the number.
