Ya i still have to research which injectors and what i need to do with the fuel pump. Im also broke from buying this tuner and laptop. Gotta wait till payday haha
in that case look at it like you now have lots of room to grow in the future. fix your currant tune up, then at least you own th etuner and that part of swapping to corn will be much easier then.
Well ya thats why i finally just took your advice cause i was just going to spend the same amount of money on a one time tune but itd be done by someone who knows what there doing but then i figured it would be really nice to know how so i can not have to pay someone again when i want to go e85
Hey quick question i got the dhp loaded on the computer but wont have the actual unit till tomorow. I thought id load up a bin just to mess around and get used to it but its telling me i havent purchased support for this vehichle blah blah. Is this only because im in demo mode and havent registered it yet?
you need the dhp unit first, cant do a thing till you register the cable. the unit needs to be plugged into the car, key to run, and the laptop, comm port set up and then it will open the dhp program for you and you have full use of it.
registering the cable means syncing the laptop up with the dhp unit really.
Ok cool so lets say were talking dhp here. If i want to get rid of the 1 degree of kr, is the fastest way for that just to lower all the. Bad and good spark tables down?
I would just lower the good fuel spark table. you just need to see which cell has kr, then lower the timing in that cell by 1. you do not want to go lower than 10* of timing advance.
edit for more info: download UV Scan and use it for scanning. it is far superior to the dhp scanner.
I would log and scan before doing any changes...it could just be starving for fuel and need a little bit to knock down the kr..are your trims getting better as you drive? What are they currently?
