suitercrew
Ahhh!! Its so confusing. Ok so the l36 block has those three bolts that hold that stand on correct?
Sent from my LG-D851 using Tapatalk
the ones that fit the holes in the block.
No, I meant the head size. I need to know what tools to bring to the JY. I wanna say 13mm.
that bolt for the pulley on the stand maybe a 15 mm, or a t55 torx bit. the pulley needs to come off to get to the stands bolts.
Hope you have the nut as well for that tensioner..it's a one off thin wall nut..this is the best pi i have. i used to have two studs, now only one. and i used a bolt on the lower hole.
the tensioner needs a thin walled 13 mm deep socket. a 12 point socket seems to fit best.
the missing idler pulley you need the bolt for it too, it goes into the bracket on that bottom part thats sticking up.
you can see how the tensioner should look too.
pulley bolts all come off, they all bolt into something, pulley spins free all the time on a bearing. all bolts are normal threads too, not reverse threads.
So the last question i have is the pulley that is underneath the water pump and tensioner how does it bolt to the block cause its not on the coil brack or heads?
