no he will have more than a stock gtp. and headers on these cars net at least a 20whp gain. i believe it was done on a stock bonneville and the headers mod made 29ish whp. if youre running the same power on a top swap as a gtp then youre doin something wrongi highly doubt it, more like a few more if not the same as a stock gtp
id say theyre dogs in the top end given the wide gearing. but hes doin a top swap with headers as well as a few other mods. if hes a good tuner he should be close to 275-280ish chp.i've never driven a GTP, but my top swap with headers and 3.29's from the factory.... its not exactly what I'd call "quick" so either stock GTP's are dogs or my car is messed up.
Matt, about the trany, is the gear ratio differential 3.29 (for some GTP's)? I thought mine (2000 XAB) was 2.93. Could there be something in the sprockets that is different? I drove a 1983 Cutlass Supreme before I had my GTP. That ride felt like a dog compared to this ride so that could be why my GTP seems fast, I guess.i've never driven a GTP, but my top swap with headers and 3.29's from the factory.... its not exactly what I'd call "quick" so either stock GTP's are dogs or my car is messed up.
Oh, ok. Got it. But could that significantly change the driving experience for a Top Swapped GT from the GTP? Could the gear ratio differential make (that much of) a difference?The only GTP's to get 3.29's were the CompG's. Matt like myself has a supercharged GT. Gt's had 3.29's
I am not doing a top swap any more and am doing an L67 full engine swap so I will basically be set up like a Comp G with headers and a tune right? I am not going to waste my money on the cps cause everyone says they are junk but now I can also go to a smaller pully on a l67 motor so I will be looking for a smaller one before I send the pcm for the tune. I am also adding pacesetter ceramic coated headers, msd wires, cai.id say theyre dogs in the top end given the wide gearing. but hes doin a top swap with headers as well as a few other mods. if hes a good tuner he should be close to 275-280ish chp.
Edited: Sorry may be off topic.
