Question... NO
You should fix the rocker pics. I'd like to see them. Even though I've pretty much decided not to every do anything with mine.
Decided to do some maintenance I Have been putting off for a while on the money maker.
Driver side I already dug into when ntb ****ed **** up, decided to replace everything anyway, still looks clean
20180127_140659 by Corey S, on Flickr
I bet this would explain the break womp womp sound and the clicking sound
I bet that bearing is dead
20180127_142301 by Corey S, on Flickr
Lovely pit holes
20180127_142352 by Corey S, on Flickr
Tack welded nut on that tie rod, thing was loose as a goose
20180127_142307 by Corey S, on Flickr
Said **** it and replace both inner and outer tie rods and the sleeve
20180127_175026 by Corey S, on Flickr
Changed the filter on a rebuild with 15k, I hope they forgot to clean **** when trhe rebuild was happening. I know I tow but sheesh only the mazda 3 I had detroyed red fluid faster
20180127_151646 by Corey S, on Flickr
20180127_151955 by Corey S, on Flickr
Tmw I have to flush the rest of the fluid out and hope all stays well.
Took it for a quick cruise over the boarder for obvious expired plate reasons, I always forget how hard this thing pulls.
41990634_1197024343771148_3055487687684259840_n by Corey S, on Flickr
Get back home decide to pop the hood to just give everything a quick once over. Standing there with the boy I hear water hitting the turbo down pipe. I did just rinse it before driving, but looked closer and the ****ing fuel line is spraying gas on the exhaust pipe!
41774646_580059535729803_5378205318461259776_n by Corey S, on Flickr
Maybe perhaps I need to heat protective wrap those lines since they sit right above the exhaust and stuffed in the back? And yes it still runs lean:) 13.3 afr wot and leaning.
