So its alive...... as of right now no fluids leak. But talk about a stage 2 turbo cam disappointment, I sure aint gonna brag its "cammed." I expeected SOMETHING not nearly nothing different from stock, to me the sound was worth the wait and work, now so far not so much. Idle is 900rpm so maybe if I drop it to 700 I can get something.......
So I guess I will start from the beginning, pulled the pump fuse cranked it a good 10revolutions, put fuse back in and cranked it until it fired, bout 3 full revs. All if well no banging or nothing but dam **** smoking all over the engine bay, exhaust burning off the oil oh man. smookey
20170903_143520 by
Corey S, on Flickr
20170903_143544 by
Corey S, on Flickr
Oil conformation
20170903_143720 by
Corey S, on Flickr
Gonna have to take care of this, it went high as 54 at idle, but once again 0 while driving or in boost
20170903_160356 by
Corey S, on Flickr
So I got the balls to go drive it on the road as the engine seemed to be holding together. I brake boost a little in park and hear a clank, back to the tools. Just turns out I needed to put another bolt in the aluminum dog bone mount to the head, oops.
Back to the road, try to hit boost it builds but it aint shifting. Its stuck in first no matter what. So I finally go around the blockin dam first and see the check engine light on.
20170903_145037 by
Corey S, on Flickr
So I took off the TPS, clocked it and turned it against the spring and deleted the codes. NOW I actually have the throttle response and turbo power I was expeceting AND I have all gears back! Driven it a few miles, few WOT and all is good so far. previous tune still, 0kr top of second and lost about 4ish psi, im just about 12psi right now.
Alt sits down below and I have the heater core bypassed right now as I want to make sure the fittings dont leak then I can run the hoses to the correct locations. And my new belt size is 81.66"
20170903_143927 by
Corey S, on Flickr
20170903_143940 by
Corey S, on Flickr
And a quick vid of the so called stage 2 turbo cam
https://www.youtube.com/watch?v=NIitExRRU_A
As of right now im glad everything is ok, but other than that I am alittle disappointed. I hope a tune more than makes up for it and all my changes dont fail....... Will also recheck exhaust components to make sure they are tight and leak free before I try any tuning.
