How thick is that spacer?
You've got an F-Body/Vette bolt pattern now.
Go get better wheels.
Naaaaow.
What a set of those set you back and where did you get them?
...have fun trying to fit a wheel with okay specs now that you've got an automatic 30mm more offset.
Isn't there an adapter plate that is less than 30mm??
i think you can get adapters in as little as 15mm thick, but the issue with that is you'd have to trim down the stock wheel studs. 25mm or more allows you to not have to do that in most cases.
Or you could run virtually any 114.3 wheel that you want.
I'm not hating, just unsure of the point, especially when you're already not flush with an 8" wheel. Basically handicapped yourself into running >8" wheel
Like this guy said: ...have fun trying to fit a wheel with okay specs now that you've got an automatic 30mm more offset
Clean car though!
Well I'll eventually upgrade to the WS6 Trans Am wheels that are 17x9 with the same offset of the wheels I have now, then I'll be able to run a summer tire on those. I really like the style of these wheels because I feel they match the car pretty well also. I don't feel like buying new wheels for this car anymore, I'm just about done with it.
