thomasd2010
Hey I just did a recent engine swap. A 99 grand prix gt engine 3800 into a 2000 grand prix gt 3800. If I put the pcm from the 99 into my 2000 will it work fine ? Or does it need resetting or anything?
99-02 PCM's are all the same...so yes. As long as it is still an L36 PCM it'll be fine.
oh its on but not fully its only got three bolts because one of the threads wouldnt come up enough for me to put the 4th bolt on.you don't have the crossover on at all? No wonder it's running like ****.
Why don't people remove plugs when doing headers?
I've yet to crack a plug with them sitting on the cowl.
the headers crossover pipe is what im talking aboutAre you trying to put the front or rear connection point together? Stock or some other exhaust? I'm confused by your description.
Either way, I typically use the bolts for it or that came with it. If you start all the bolts before tightenting anything, it should go very easily.
