hahahah I will win!!!!
1. headlights need replacing
2. passenger high-beam wire has been cut, not by me.
3. corner lights have hella moisture
4. was keyed from front of passenger fender to the rear quarter panel behind the wheel well
5. fogs are shvt
6. rear view mirror kept falling off so I have a soda tab wedged in to keep it in place
7. driver window tint is shvt (cant see through, have to roll down to turn left)
8. driver seat is worn out, not ripped, I'm just fat. lol
9. cruise control doesn't work
10. traction control doesn't work
11. ABS doesn't work(thank God)
12-13. rear pasanger window doesn't roll down and the tint was cut and pealed mid way up
14. rear wind screen window tint is a blurry mess
15. driver side rear door doesn't lock with pwr locks i.e. its manual now
16. trunk light mount is broken and the bulb doesn't stay in the socket
17. Race-peal rear bumper
18. driver seat manual lumbar support works but has been separated from the mount in the seat.
19. there is a score in the windshield were some dumba** took a wiper off one side and used them like that...
20. dent in rear quarter panel, about the size of a fist.
ha ha ha number twenty and I'm just now getting into the major mechanical issues...
21. Exhaust leaks from down pipe, crossover, and front manifold <gasket was replaced no change>
22. is on its fourth axle
23. rear tires wear on the inside after alignment was done. need new cam bolts I was told (I called BS and they wouldn't do anymore work because I was an a**hole)
24. rear pad was bent from whoever did the breaks before me, HTFk Does that happen???
25. emergency break doesn't work
26. S/C coupler needs replacing
27. Burnt the PLUGS out of cylinder 1 & 3 some how.
28. possibly have FVCKED piston head
29. obvious issue with exhaust valve in cylinder #1
30. BBV fell apart
31. needs all 4 hub bearings
32. needs front ball joints replaced
33. rear defrost light on hvac controls is out but defrost works
34. PERF SHIFT light out but works
35. Low Coolant light is always on and never low..
One great BIG positive thing though...
IT's RUST FREE!!!!!!!!!
