Old Thread
Re: The "Whats Wrong With Your Car Thread" Post Your Issues Here
I must have the shortest list here...04 Comp G with 65k miles.
-HUD cover cracked
-Monsoon 6 disc broke almost a year ago (really tired of just AM/FM)
And that's it...been pampered since we bought it for my wife in December 06. It doesn't even have any surface rust. We've fixed a fair number of things over time, but I've always stayed after it because I'm a picky bastard...
Blew my engine in by 01 GTP the same day I was putting it in storage so now I have a five cylinder block lol.Good news is I found a donor car a 01 GTP with 200k km or 124k miles on it for four hundred bucks so now I will have to get my car put back together this winter.Then I can sell what ever I don't need and get my money back good deal all around lol.Will do some mods too as I will have the car all apart.
hahahah I will win!!!!
1. headlights need replacing
2. passenger high-beam wire has been cut, not by me.
3. corner lights have hella moisture
4. was keyed from front of passenger fender to the rear quarter panel behind the wheel well
5. fogs are shvt
6. rear view mirror kept falling off so I have a soda tab wedged in to keep it in place
7. driver window tint is shvt (cant see through, have to roll down to turn left)
8. driver seat is worn out, not ripped, I'm just fat. lol
9. cruise control doesn't work
10. traction control doesn't work
11. ABS doesn't work(thank God)
12-13. rear pasanger window doesn't roll down and the tint was cut and pealed mid way up
14. rear wind screen window tint is a blurry mess
15. driver side rear door doesn't lock with pwr locks i.e. its manual now
16. trunk light mount is broken and the bulb doesn't stay in the socket
17. Race-peal rear bumper
18. driver seat manual lumbar support works but has been separated from the mount in the seat.
19. there is a score in the windshield were some dumba** took a wiper off one side and used them like that...
20. dent in rear quarter panel, about the size of a fist.
ha ha ha number twenty and I'm just now getting into the major mechanical issues...
21. Exhaust leaks from down pipe, crossover, and front manifold <gasket was replaced no change>
22. is on its fourth axle
23. rear tires wear on the inside after alignment was done. need new cam bolts I was told (I called BS and they wouldn't do anymore work because I was an a**hole)
24. rear pad was bent from whoever did the breaks before me, HTFk Does that happen???
25. emergency break doesn't work
26. S/C coupler needs replacing
27. Burnt the PLUGS out of cylinder 1 & 3 some how.
28. possibly have FVCKED piston head
29. obvious issue with exhaust valve in cylinder #1
30. BBV fell apart
31. needs all 4 hub bearings
32. needs front ball joints replaced
33. rear defrost light on hvac controls is out but defrost works
34. PERF SHIFT light out but works
35. Low Coolant light is always on and never low..
One great BIG positive thing though...
IT's RUST FREE!!!!!!!!!
oh and the battery is crap sometimes
I actually have a spare battery that is good. Only a year and a half old. I thought it was bad and got new one. But it wasn't
yeah I need a poor bastard to buy my car for $2500 lolz and gets my monies back
ohhh... 1998 gxp lets do a v8 swap dirt I need your motor lolz
No.......unless u buy a 5.3 and I'll help put it in :D
im going to look into it. who's done it?
No one I know of. Seen it done in a couple other cars but I don't think it'd be hard since it uses same sub frame as v6. Ud need motor/trans and motor mounts. And probably then some other small things
lets do it, im going to start saving... BRILLIANT! I need a Write up, FVCK it im going to make one
Wow...not sure what kinda expenses you would see with it. Us also need a tune (I have hpt) and harness and probably lots of wiring is think.
moved to my other thread the "Welp" one
-Ever since doing the ssm90 kit from zzp I have MASSIVE issues with fuel trims during warmup and long idle. (No it is not due to the position of the injectors) It is probably because of the ****ty fuel lab regulator.... Haven't decided on how I want to replace that one yet.
-Engine starts then immediately dies on warm starts after putting the northstar on. (Its not the iac I checked). Probably a misadjusted throttle plate but I am too lazy to mess with it.
-Noticible tick from the engine after I shattered my stock harmonic balancer and then replaced it with a 8 rib one. It still runs like a top and squishes turbo rice rockets so im happy.
-Havent had the key safety solenoid for the last 50k miles. Got tired of having a stuck key so I ripped it out and never looked back.
-Ever since flashing a gtp bin, if I program in my correct gear ratio the thing SLAMS INTO GEAR VIOLENTLY like im talking chirps the tires from a standstill with no throttle. On wot pulls when shifting into 2nd it will pull all timing for the 2nd gear shift and then wont give it back until I let off. If I lie and say the gear ratio is slightly taller then it really is the transmission shifts smooth as butter and has no issues whatsoever. Not sure whats going on there because everything else is right. Even the speedo is correct. *shrugs*
-If I tune my traction control to be safe for the engine it does no good. If I tune it to be useful I risk blowing it up.
-I pinched a wire going to my fuel pump rewire. Have been running my race pump off the stock harness for a week now and I have only blown the fuse 3 times.
-My hid retrofits currently like to shut off while driving. I think the relay is ****ting the bed
-My taillights collect water for me
-There has been a weird front end clunk for the last 20k. Has new control arms, tie rods, ball joints, and rack. Even a shop couldn't figure it out. Oh well it drive in a straight line even at WOT
But on the bright side I have a absolutely goofy powerful fwd instatorque monster that I trust to drive accross the country and back. 170k and counting.
no fuel gauge, no clock in the radio, and in desperate need of a keyless entry key fob on the CHEAP!!!!
I have a random clunk almost sounds like popcorn. During acceleration and turns toward the left
