Nic or XP?
Got my overkill cam coming, with my 1.7 roller rockers should run good. I will post dyno results. Going for 290whp. Ported gen three, meth with blower spacer, all the other bolt ons. Waiting on a few parts :-)
Sent from my LG-L38C using Tapatalk 2
Get a gen 5. You can find them cheap nowadays. There is a guy that just found a brand spankin new one and paid $65 for it.
Ported is just as good unless its a terrible port job you would see the same gains tek310 would tell ya keep the ported gen 3 lol
Sent from my SAMSUNG-SGH-I747 using Tapatalk
Incorrect. Ported is not just as good. Any untouched gen 5 will still be more efficient than any port job on a gen 3. It's been proven.
What do mean not as good? Can you explain? Lots of people and guys I know could Care less for buying a gen v and porting their gen 3 im just curious to know they always shown and said a ported 3 is like a gen v
It may be ported to flow as good, but it will never be as efficient temperature wise than a gen 5. One of the main reasons guys convert to a gen 5 is for the temperature efficiency over a gen 3. Plus it wines a lot more ;)
Actually I have heard that a ported gen3 whines louder then a GenV
As having run both, with the same size pulleys on both, the Gen V whines louder than the ported Gen III.
Also, no need to port the outlet on a gen V, you can smooth/blend the inlet to reduce turbulence, and port the inlet larger if you are running a larger TB and MAF.
I've never run a ported gen 3, but my gen 5 whined a ton more than my stock gen 3 with the same size pulley. I remember reading on clubgp in the past that a gen 5 whines more than a fully ported gen 3 once you drop below a 3.0 pulley.
A gen 5 hands down has the edge over any ported gen 3. This has been discussed upon for years so I don't understand why, in 2014, anyone in this dying platform would still think a ported gen 3 would be the same as a gen 5. Although if you do not plan to drop to a 3.0 or below, then a ported gen 3 would work fine. The gen 5 does not really start to shine until you are below the 3.0 range.
Oh I wasn't debating the benefits of a GenV over a Gen3. I was simply commenting on sound.
I'll agree with the whine gen v cried and whined like a b***h on a stock pulley lol when I did a wot run:cool:
You should hear what mine sounds like on a 3.0. Starts whining at 2k under normal throttle. I can't to drop to a 2.8 this spring ;).
