Well it's a bad news and bad news kind of night. Got the subframe up. Connected the steering wheel. And lost the 11mm bolt for the knuckle. And at the same time I have cleaned up everything looking for other leaks and guess what? The transmission pan has a leak.
So what size bolt?
Is the transmission pan gasket hard to change?
Bored at work update thread.
Other question - the plastic shield over the crank pulley broke into many pieces when the belt let loose. Any idea what that is called
imho : local junkyard would prolly be cheapest.
Also just FYI - I did not have a brake line clamp and could not find vice grips so the lines are slowly dripping. I have a kid go out every few hours and top off the reservoir. At least I should have partially clean fluid when I put the brakes back on.
