WolvesSoulZ
OI,
I've been chasing some KR since a while. I've got my PCM retuned a few times with different logs. (Yeah I figure Torque isn't the best app for logs.)
Mods are : ('04 Comp-G)
XP Cam (LS6 Springs / LS7 Lifters(I know not really a mod.))
3.5" Pulley
3" Catless downpipe
Powerlog
Ported Rear manifold (Just a wee bit.)
DIY Intake with that 9" spectre filter(Less than a year old), MAF gets a clean up a year, at least.
Not a mod, but heads were fluxed and decked, valves had jobs done and some were replaced, when I did my cam.
I have AL104 plugs gapped @ 0.054 and a 180* T-stat. (Less than a year old. Replace them @ about 15-20k KM or so.)
Rev 5 or 6 of my tune with Overkill.
I don't think anything is hitting anywhere.
Car puts 2-3 car length on a 3.4" Intercooled/ZZP Headers 2006.
If I remember well, I had less KR before winter, then now after winter, I seem to have a bit more.
Sometimes I have none @ WOT, sometimes I have some at the top of a fast highway merge @ around 110-120kph.
Cruising on the highway, when I hit a steep hill and it stays in 4th, boost gets capped at around 4 PSI and I see blips of 1-2*KR
KR most of the time seems to be between 0 and 2* ish. Sometimes even @ 10 PSI of boost, there is none, sometimes @ just 7-8 there is 1-2*.
Here's a log I saved with KR highlighted in Orange. Highway log, you can see where I hit hills, and where I merge.)
http://upx.nz/xvpeZG
Any clues?
(I know some guys around here have similar set ups as mine, IE, no full headers, but Cam and plog/dp that runs 3.3/3.4 pulleys.)
3.5" Pulley
3" Catless downpipe
Powerlog
Any clues?
