JDrach's 98 Daytona - Snappin chains 4 days
Re: JDrach's 98 Daytona
Sad day....crossed 80k mark
Here's a comparison of the glossifier on my car vs just dip on my friends red car (excuse the bug splatters on his, he drives to BFE alot.)
How many coats of glossifier did you do? Cause I know I used the metalizer before and the more coats you put on the more change you saw.
Yeah when i did my wheels and layed down the black it was super flat. That glossifier matches the paint well. Plasti dip is a cool product. And I just went to a car wash power washed my wheels didnt even peel off if you put a thick enough coat on them
Ya apply and prep it well and they will hold up. Nothing beats fresh paint and powder coating.
Should have a pretty good update within the next few days and this weekend :) I'm excited.
too bad you wont take advantage of this update because you drive like a grandpa :)
Alright well took it on the highway for 20 miles and reset the DIC. Got 41mpg....cruising 65mph. Hmmm....Car sounds a lot different but I like it so far. Can not wait to bring it to Paul in Indy to work his magic.
Issues so far : Idle around 750 and jumps up and down alot (around 600-850 rpms), misfires from 2-12 on Cylinders 3 and 5. Its random though and barely happens. Drove 20 mins home tonight and saw it a few times popping up then went away..... Then my vac's reading around 15 PSI at idle. Even with AC, but I know thats from the cam install. Still going to replace my T fitting for my boost gauge, its cracking. Little puzzled on the misfire though. Running AL103's now, not sure if it just needs a tune or what. My car also was running lean for 10 mins on the highway mentioned earlier, flashing between -10 and -6 but then it went to +-3, which was more normal.
Re: JDrach's 98 Daytona- XP'd
I actually need not see the P0300 code when i checked on my aeroforce, just my ABS TC code. But I totally forgot the XP will throw the P0300 misfire code. Cause i was flipping through my parameters on the gauge and saw 2 on Misfires so I brought up the table for the cylinders and saw them on 3 and 5, and maybe 1 all up front. Why does the cam throw this code and how come it doesn't effect performance even though the gauge read live feedback of the misfires? And also, is the valvetrain noise normal?
Damn:(Makes me wanna go straight to a tuner after I do a xp install after hearing this
Sent from my SAMSUNG-SGH-I747 using Tapatalk 2
The second video was for that. Unless you want me to rev it and video under the hood?
