and never use scotch brite on engines. i read it somewhere that its leaves small metal pieces inside your motor
Why does everyone here think it will help with performance gains? It does nothing for performance AT ALL except make the blower sound more audible at idle. This is the stupidest idea ever. And you can't weld the case either...it might warp it...so goes "explore" your ideas to make it work...and we'll run a non-ported GTP vs. a GTP with the slots filled and it won't make a ****s lick of difference. Now if you care to dyno your car before and after on the same dyno, same mods minus the slits filled, AND same air temp...and you make more power...then I'll laugh...and say something was wrong with the dyno. /This Thread.
The simple fact is that they do reduce efficiency, period. Think about it, you're feeding air back into the blower, how can it not? This is an OEM blower, so a small efficiency loss is worth it to keep it quieter.
You know, this has gone back and forth on every site for blown cars that I've come across, all with no hard numbers either way. What I have seen more than once are statement from people inside eaton that the holes are there to reduce sound by allowing some backflow. Feeding already compressed, heated air back into the rotors to be compressed and heated again can't be a good thing for efficiency, can it? It sure as hell isn't going to be a seat of the pants difference, I'm not arguing that.
Then again, we're screwing up the efficiency by putting on a smaller pulley anyway, so who knows.
Doesnt matter either way, its just the thing to do when you port a blower.
do i need a machine shop to do that or can i do it with my dremel as im pretty good at polishing with it already. how far can i go with it if i do?No...the thing to do when porting a blower is hogging out the stock "V"...not filling the holes :th_shakinghead1:
again...how far can i go then? i dont wat to cut too much out
and thats why im now gonna send you a friend request!!!!!!:th_laugh-pointup:Oh I'm sure Logan has pictures of blower's he has done that he hasn't shipped out to paying customers yet that he can post up here to show you.
