Bigbm80
I was taking off the stock 3.8" pulley to put on a 3.4" and everything was going fine until it came time to take off the 3.8". I put on the pulley puller and it wasn't a traditional one but instead one with 2 claw like things but i figured it would work. So i put it on the pulley and started to turn it. Instead of pulling the pulley off, it bent it... A LOT, prob because the pressure wasn't evenly distributed throughout the whole pulley but instead two points. So I turned the puller 90 degrees started to pull again and that started to bend. Now it kinda looks like a wobbly square and hasn't moved and inch. So now i cant even use the car cuz the pulley is bent so much that I cant use it and I cant use the new one because I cant get the old one off! ANY ideas on what to do??
