no you don't I have a 03 SE cluster in my 97 the gas gauge has a problem because it connects all 4 of the sender poles as where 97 only connects 3.. it's a pain but it will use whatever cluster just use the back of your 97, swap the odometer and put the face plate back onYou need a 97 cluster
So it wasnt the spark plug wires. Wtf
Well I meant if he wanted everything to work correctlyno you don't I have a 03 SE cluster in my 97 the gas gauge has a problem because it connects all 4 of the sender poles as where 97 only connects 3.. it's a pain but it will use whatever cluster just use the back of your 97, swap the odometer and put the face plate back on
Sent from my SGH-M919N using Tapatalk
Ahhh this I did not no and yes makes very good sense now!See Kold.. if we remember, Tim swapped his diff, then an engine, then the trans.
Anyone who's swapped a motor, likely knows why I'm saying.. check your grounds.
