Gauge cluster+ wheel speed
Status
Not open for further replies.
Dude get a cluster then pull the face and swap the odometer done.. mileage is correct
Sent from my SGH-M919N using Tapatalk
You need a 97 cluster
no you don't I have a 03 SE cluster in my 97 the gas gauge has a problem because it connects all 4 of the sender poles as where 97 only connects 3.. it's a pain but it will use whatever cluster just use the back of your 97, swap the odometer and put the face plate back on
Haha man he'd have to have one of those in order for that to be the reason.. Palmela doesn't bleed lol
And it's just the rpms right? If it's revving a little different I'd say maybe something to do with the throttle body.. carbon build up etc
Well if your not having any issues ie revving, driving etc and it's just the cluster I'd have to assume it's either as Bill said a ground but I don't think one would just get messed up OR it's a sensor which can mess up randomly and seems to be more reasonable of a reason
Well I meant if he wanted everything to work correctly
See Kold.. if we remember, Tim swapped his diff, then an engine, then the trans.
Anyone who's swapped a motor, likely knows why I'm saying.. check your grounds.
It's like....if you swapped a motor and all of a sudden your traction/X and Y don't work.. you might have a ground issue.
Status
