Slick2500
Active member
Didn't Qfast or whatever his name is with the turbo camaro use modded zzp plogs?How about flipping V6 F body manifolds like FurchesPerformance does and putting it out front?
I'm not sure how you mean, Any pics or links? The F-body manifolds both work perfect is it's lower, it moves the coolant thermostat housing forward and makes turbo plumbing easy
One of my main goals was to stay away from a V8. I originally considered 4cyl engines like Nissan's SR20DET. Eventually V6's starting popping up.
Ha, Me Too!!!
Was looking at the F-Body manifolds. Everything looks good, I'll likely need the LIM, Upper/plenum. Fuel rail and MAYBE the throttle body...
Can anyone confirm if the F-body's have the same throttle body as the GTP's?
Then I gotta close up the injector holes in the heads.
Some of the fbodies used drive by wire throttle bodies iirc. But the cable ones were the same as the l36 tb irrc.
Ah good. My only real concern is rather the flange is the same and if i'll run into any issues with the coolant passages if they happened to changed them. If anything I can just weld em shut ha
Are you going to ever run it on SC or go straight to turbo?
Funny people mentioned the block twisting. My factory l67 ate the front main journal and killed the oil pump. I replaced the crank with a 10-10 ground one because it was a little scored. Replaced the mains and rods with no line boring. Ive got probably 15K+ on this engine and no problems.
News to me!
This thread is more proof GM makes the best rebuild kits for blown rotaries!![]()
sub'd. Where you at in Northern Illinois?
