dblackston
Thanks!! Yes, I think that may be the plan going forward...may re plumb it all. I still also need to locate the IC fluid res...assuming there is one or add it if needed. .
and whats that red thing bolted to the vac tree top rear of the blower? thats a fuel pressure regulator or something?
Replace those msd coils packs with stock ones ASAP! I can sell you some, I have extras.
The msd coils are worse than stock unless you have the entire msd ignition setup.
You should get rid of the throttle body spacer too, that's a vacuum leak waiting to happen and there are really no benefits to it.
If you are looking to do more performance upgrades then you should consider a Gen V supercharger and northstar throttle body setup. There is some pcm tuning involved but it's not that bad. And you could reuse the Intercooler with it, you would just have to open it up a little more to match the lim and supercharger.
Yes, it is the pressure regulator I believe for the PRJ fuel rails. The only paperwork I have on the IC is zzp install instructions for a stage 2 kit. I dont believe the PCV is functioning at all as it also seems like it will spit oil from the breather cap. Yes, I should have cleaned the Coolant res since I had it out but didnt as I got lazy and needed to though the car back together to take it for an emissions test, the whole engine compartment could benefit for a decent cleaning in general.
Any easy way to see if the IC is blocking the PCV ports without removing it altogether or easiest to just reroute it in the manner above?
you might be able to take the cap off the supercharger and remove the pcv valve and other items from the pcv in the supercharger to see if there is a blockage.
They are.I thought the new ones are fixed
**** at that price its not even worth your time to clean.A new coolant tank is $14 bucks plus shipping on RockAuto.....
https://www.rockauto.com/en/catalog...3,cooling+system,coolant+recovery+tank,10457\
If the pcv is functional due to the spacer then take the spacer out and drill and tap the brass plug in the bottom of your throttle body and put in a nipple to run the pcv hose too.
looks like a gen 3 blower to me. so the pcv dont need to go to anything if theres no suction from the valve cover, that would mean hes got functioning pcv,
but this could be a older ic core and not have a working right pcv and need the hose from the v/c to tb. and then ditch the breather. breather is letting in un metered air and messing with your tune some for sure.
