Re: Installing new cam
Maybe a bit condescending... And my intention is not to offend...
But it would appear that maybe you've decided to bite off more than you can chew. I only say this due to the questions being asked -vs- the things you say you'll do. Also, without any prior knowledge or experience you will rebuild your tranny? Hmmmmm... Ok!
Maybe it's just me but that's not something I would do (Tranny), simple or not! Second is not knowing certain other simple things such as when replacing cam, what needs to be done along with it (to or not to remove heads). The cam is definitely a doable project, but there are some caveats! You should have a plan which you obviously don't. And don't say you just don't know this engine cause if you've done some research, you'd have found most of what you need to know without asking. I can only surmise that if there is a failure on this project, you will say because someone didn't tell you this, or that. Do yourself a favor and spend a little more time putting a plan together, researching all you want to do, make lists, assemble tools, parts, material, double check all, research some more, make revised lists, then ask. Or will you stop by here and ask torque specs for certain bolts as you reassemble? Just an example!
I for one will watch this thread... if for anything, out of a morbid curiosity!
