Cam Lope vs timing chain
jrb1027
Hi I have a question about xp cam, I want to be able to hear the lope of the cam so I will need to set the idle low. Is this hard on the timeing chain?
I have my idle set lower in Park and Neutral. So when it's in drive (98% of the time) it's not as bad on the chain
If you want lope,do the double roller.Just remember to machine the correct camfer into the crank sprocket.
Well looks like im going with a double roller anyways its comeing with the cam and heads. So you guys think i will be ok with a little lope, its an xp cam and 90#springs
You should have 130s with an XP... I ran 105s forever and thought they worked just fine.
Until I saw the dyno sheet when I finally put the 140s in.
