Budget Comp G. 2.5" pulley = no belt slip
Re: Budget 04 comp g running total $2670 Lowered :D
That doesn't look bad at all..pretty much looking like ssc's to me..how does she ride though??!
Hot Dam that looks good just like the SSCs....really what is the verdict on the ride
Did you stick with the initial cut length?
D is doing some GP VooDoo
Ride is firmer than stock but still pretty nice. I just cut a 1/4 coil off so it's not to much. It's about a 1/4" shorter in the rear than the front now dangit.
I found a local car lot with a gp with a sd lip. I'm stopping by tom to see if I could take it and put my stocker in it's place.
7mm socket is needed & panel tool. , might also need a philips screwdriver.
make sure you get the spacers too, those are key. it needs a firm pull to get the fascia out, but dont break anything ;)
I'm hoping they will trade plus like $50 or so. That would be awesome. I need that lip.
probly 75 most will say no I remember when I ask they said no bcause some are molded to the bumper
Well I'm starting on this bad boy once I get the trans swap done that's in my garage :D
Just put it up on the engine stand yesterday to make room in the garage and to get it off my trans jack.
Well after 5,347 miles the motor has decided to call it quits. I spun a rod bearing. I'm thinking that was the noise all along but I'll find out if I have any chipped pistons after I get it pulled. :( sad day for the comp g.
But look on the bright side you can finally get your build engaged !
I'm going to start pulling the motor tonight and hope to have it out tom and then get my other motor put together. I'll be happy once it's done.
Re: Budget 04 comp g running total $2670 Now with rod knock
S1x p&p heads and sd headers for now. I'll ic down the road.
