bleeding brakes is super easy. have a friend pump the brake pedal up and hold it down, you yell pump em, then hold em, then you crack the bleeder open till no more fluid comes out, you pal on the pedal pushed the pedal down and holds it there till you say pump em up again. so as soon as fluid stops coming out you shut the bleeder so it cant suck air back in.
or you can make a one man bleeder, i made one, it works f ing great. its nothing more then plastic bottle with 2 holes burned in the top, you put 2 inches of fluid in the bottle then push a clear plastic tube that fits the bleeder nipple through the cap and into the fluid at the bottom, then hook it to the bleeder nipple, open the bleeder, then pump the pedal slowly, this will flush all the fluid rather fast.
the tube in fluid keeps air from being sucked back into the caliper.
